06-29-2016 09:14 AM - edited 03-18-2019 06:05 AM
Hi All
We have a scenario that my user wants to use 3rd Party ceiling Microphones with LED (Red for Mute & Green for Unmute) via Cisco Touch Control mute and unmute option.
We do not have any control System.
We are using Baimp Audia Flex.
Appreciate if any one can advise.
Aabid
06-29-2016 10:24 AM
The only microphones the codec itself can control and give led status indication of mute/unmute is the Precision Microphone 20. In order to control the Baimp Audio Flex microphones, you'll need a control system and use the in-room control functions of the Touch 10.
06-29-2016 05:43 PM
HI Patrick
Thank you very much for the reply.
I had read some where that if the GPIO of the DSP will be used then we can control the rrequired but unfortuanetly i cannot find the link now.
06-29-2016 06:51 PM
Are you aware that Biamp does not recommend the use of Ceiling Microphones, especially where AEC is used. See AEC_in_Audia_and_Nexia
While commonly used, ceiling mics are problematic for the following reasons:
For all these reasons, and from our years of experience with AEC systems, Biamp Systems does not recommend using ceiling microphones if it is practical to use individual mics for participants. However we recognize the aestheic bias toward micing from above and will work to help get the best results possible with all configurations. Understanding the inherent issues and common problems faced with these installations is an important step for every designer/installer.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
