11-16-2015 07:35 AM - edited 03-18-2019 05:13 AM
i search a router ISR which support 150 user or more (ip phones user), cisco 2911 support tha number?
11-16-2015 07:54 AM
This is proabbly the sheet your looking for , remember 2911s only support around 180mbps throughput and thats without crypto etc so you need to calculate your thrpoughput based against the codecs in use too
http://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/series-comparison.html
11-16-2015 08:59 AM
okey thank you Mark, i need 1GB minimum RAM expandable. what i should choose.?
so if i choose 2951, can i expandable RAM to 1 GB?
11-20-2015 04:06 AM
Moussa, you have mentioned you need router to support 150 or more IP phone users. Are you planning to register IP phones on ISR (CME) ?
Cause 2951 supports up to 150 IP phones maximum (SCCP or SIP), and recommended to have 1Gb RAM/256Mb flash in this case.
Check this out http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
If you have plans to expand number of phones, you will need Cisco 3925 or ISR 4451 (maximum 250 IP phones)
