Outbound SIP Calls Not Working
petenixon
Level 3
Level 3
Hi guys,
I've got an issue whereby I am not able to make outbound calls, but inbound calls are working ok. A debug shows the following:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.37.17.1:5060;branch=z9hG4bK413515BF;received=10.37.17.1;rport=49418
To: <sip:84421445@X.X.X.X>;tag=as17bec629
Call-ID: 63042446-E6AF11E4-8002F3C4-CF4FA842
CSeq: 15464 REGISTER
Server: Voiceflex
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="voiceflex", nonce="65388d79", stale=true
Content-Length: 0
This makes me think that the credentials configured under the sip-ua realm are incorrect but I would appreciate clarification.
Cheers,
Pete.
Given that you appear to be trying to register your endpoint to a Voiceflex service, perhaps you'd be best talking to them about how to configure your device (you don't mention what you're trying to connect with) to work with their service.  http://www.voiceflex.com/support/
Note: Your question would be better placed in the TelePresence section of the forums where these devices are more actively discussed than in the Video Over IP section you've posted in - I'd suggest, if the above hasn't answered your query, that you move your discussion over there.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
