PE Install Fail
Justin Ferello
Level 5
Level 5
All,
Got a PE install that is failing, I reviewed the log but I cannot pinpoint where it is failing.  Can someone help me decipher this?
Thank you,
Justin Ferello
Technical Support Specialist
KBZ, a Cisco Authorized Distributor
http://www.kbz.com
e/v: justin.ferello@kbz.com
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
2 Accepted Solutions
Hi Paulo
That is not entirely correct. What you have copy/pasted here are installation properties and not the actuall error, these messages here will always be in the logs. Just FYI.
The error you are seeing Justin is:
Calling custom action TMSPECA!TMSProvisioningExt.HeraConfigurationActions.ConfigureSettingsFile
TMSPE (DEBUG): installdir, cryptclass, and jarrelpath are D:\TANDBERG\TMS\TMSProvisioningExtension\ com.cisco.ts.mgmt.lib.crypt.CipherHelper repo
TMSPE (DEBUG): Jar list: bouncycastle-jce-jdk13-112.jar;commons-codec-20041127.091804.jar;jetty-security-7.2.2.v20101205.jar;security-1.0.159.jar;slf4j-api-1.6.1.jar
TMSPE (DEBUG): Invoking java.exe from C:\Program Files\Java\j2re1.4.2_13\bin\java.exe
TMSPE (DEBUG): Java exit code is 1
TMSPE (DEBUG): Ran into exception when invoking Java code: User button states could not be set
TMSPE (ERROR): The product is not configured and is not functional. You must first uninstall and retry the operation. Exception TMSProvisioningExt.CAKeyEncryptionException: User button states could not be set
Action ended 8:29:47: InstallFinalize. Return value 3.
MSI (s) (04:F0) [08:29:47:808]: User policy value 'DisableRollback' is 0
MSI (s) (04:F0) [08:29:47:808]: Machine policy value 'DisableRollback' is 0
MSI (s) (04:F0) [08:29:47:808]: Executing op: Header(Signature=1397708873,Version=405,Timestamp=1120748458,LangId=1033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (04:F0) [08:29:47:808]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (04:F0) [08:29:47:808]: Executing op: DialogInfo(Type=1,Argument=Cisco TMS Provisioning Extension)
MSI (s) (04:F0) [08:29:47:808]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
Action 8:29:47: Rollback. Rolling back action:
So the issue is a java exception.
Try uninstalling your Java and re-install it, then re-install TMSPE and see if this resolves the issue.
/Magnus
Your PATH is not pointing to java 6 although it is installed:
Property(C): JAVAINSTALLED = 1.6
See my previous post about the same topic:
https://supportforums.cisco.com/message/3932770#3932770
8 Replies 8
Paulo Souza
This is the error:
CASqlException = SQL Server exception. Review the log file for more details.
Property(C): CAInvalidSQLServerNameException = The SQL Server name is either empty or invalid. Enter the name of the computer where SQL Server is installed.
Property(C): CAInvalidSQLInstanceNameException = The SQL Server Instance name is either empty or invalid. Enter the name of the SQL Server instance.
Property(C): CAInvalidSQLUserNameException = The user name is either empty or invalid. Enter a valid user name that has access to the SQL Server.
Property(C): CASQLServerVersionException = The SQL Server version must be equal to or higher than Microsoft SQL Server 2005. Please enter a different SQL Server name.
Property(C): CAImpersonationFailureException = Unable to logon the specified user. The user account must have access to this machine and to the SQL Server.
Put here more information about your SQL Server. Is it local or remote? What is the version? Does it have SQL Server Browser running? Are you using SQL or windows authentication? TMS version? So on...
Paulo Souza
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Hi Paulo
/Magnus
Hi Magnus,
Thank you for the correction. The log file is too big, I lost the important points.
I learned another.  =)
Paulo Souza
Thomas,
I see that now, so sorry for wasting everyones time.  I should have caught that, totally wrong directory.  We are re-installing JAVA6 right now, just to make sure.
Thank you,
Justin Ferello
http://www.kbz.com
Thank you,
Justin Ferello
Magnus,
Thanks for the clarification.  I was really confused as we could fully connect and access the SQL DB
Thank you,
Justin Ferello
http://www.kbz.com
Thank you,
Justin Ferello
Re-installing Java  does the same trick as setting the path manually although it takes less time changing it
Great that it solved your issue.
/Magnus
Hi Justin,
If your problem has been resolved I would suggest to mark the "right answer".  =)
Paulo Souza
