04-03-2018 06:50 PM - edited 03-18-2019 02:01 PM
I'm currently running some demo branding licenses on a CMS cluster. They show up in the cms.lic file as feature "branding" - how can I tell if this is "single branding" or "multiple branding"?
My aim is to setup some test spaces with different voice prompts for testing while leaving the rest of the spaces to use the default prompts, but my understanding is that I would need the multiple branding license to apply a different callBrandingprofile to different spaces.
Solved! Go to Solution.
04-04-2018 07:32 PM
The TAC ended up answering my question:
Now, how can you tell which level is which just from the cms.lic:
"branding":
"expiry": "2018-May-01",
"level": "20"
04-04-2018 08:14 AM
04-04-2018 01:58 PM - edited 04-04-2018 02:06 PM
It just says "branding"
04-04-2018 07:32 PM
"branding":
"level": "20"
04-05-2018 05:31 AM
