Route Pattern Issue
1)I am configuring the Route Pattern for my Remote Site
2)I have HO where CCM is located and remote site where via MPLS link i am trying to register my phones,phones are registered CUG calling is happening between HO and Remote site but not able to make LOCAL,STD,ISD calls from Remote site
3)My Remote site numb is 4502XXX and i have configured router pattern for STD,ISD and Local but it does not work when i apply CSS and Partition to my phones
4)Also Remote iste uses AREA CODE for dialing to other cities 0124
  Thanks in Advance for Help
7 Replies 7
ronpatel
Level 8
Level 8
In the gateway Enable debug isdn q931 and try to call the STD ISD number. Send me debug output.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Got Dial plan Analysis report for you
Your call is blocked because you have dialed number which starts from 9 "9892895616" and your route pattern starts with 0 so it will never match.
regards
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
But i have configured to remove the PRE DOT number i dial 0 first and den the number
Hi Ronak,
              In ISDN debug i dont get anything even if i dial
Is your GW regestered to CUCM properly.
Ronak Patel
HI
Also your route pattern is 0.[1-8] and you are dialing 09. So how would it match? make it [1-9]
regards
Ronak Patel
