hi all
im using 2811 SCCP PBX with 4 FXS port for outgoing calls and its running very good. i have few things to ask
1. outgoing calls are connecting slow, can we make it fast
2. For outgoing calls have to press 9
Here is my main question
after dialing 90555555555 (any outgoing call) PBX check 1st available line and rout the calls to that line
if 1st line is busy the it will use 2nd 3rd or 4th line it's fine.
but can i do it such a way that 2 lines (FXS ports) will work if i press 9 with phone no then it routes to 1st 2 ports and if i press any other no like 8 with phone no then i routes the call to 3rd or 4th port.
in short i have to specific the calls from specific FXS ports is it possible?
