session target sip-server
Hi there,
I´m trying to redirecy a dial-peer from my PBX to an sip server...
I was trying something like:
dial-peer voice 111111 voip
description Teste Softphone
destination-pattern 111111
voice-class codec 10
session target ipv4:111111@fwd.pulver.com
<or>
session protocol sipv2
but I had no sucess..
Any help ?
Andrei.
ngss
May I know what are you trying to achieve?
Your config here doesn't make sense.
SSng
ecolombo
Hi Andrei, if you like send an INVITE directly to your SIP softphone try with
dial-peer voice 1111 voip
destination-pattern xxxx
session target ipv4:ip.of.your.sf
But if you have a SIP proxy to redirect the call you need set:
sip-ua
sip-server ipv4:ip.of.your.sipproxy
and
At any time you can make a "debug ccsip message" to see how your voice gateway send and receive SIP messages.
Ezequiel Colombo
