SET MTU ON VCS
Chet Cronin
Level 4
Level 4
Does anyone know where and what command to set the MTU size on the VCS Control??? I need to change it from 1500 to 1300.
Thank you.
Chet Cronin
801-815-3539(USA)
+9379 601-3954 (Afghanistan)
Chet Cronin
Alok Jaiswal
Hi Chet,
login to root on the VCS and run the below command.
# ifconfig eth0 mtu 1300
to make the change permanent modify the file '/etc/network/interfaces' using vi command and make an entry "mtu 1300".
below is the command when i did on my vcs and when i read the same file using "cat" command.
~ # cat /etc/network/interfaces
# This file is automatically generated. Manual changes will be lost.
# Generated at 2013-08-03 03:31:21 by ni.managementframework.applications.installed.linuxmanager.etcfacade.networkinterfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
    address 10.106.93.178
    netmask 255.255.255.192
    network 10.106.93.128
    up /sbin/ethtool -s eth0 autoneg on
    mtu 1300
after making the changes you can just reboot the machine.
To verify run the command 'ifconfig eth0' and verify the mtu size.
Rgds
Alok
Alok Jaiswal
Hi Chet,
auto lo
auto eth0
    mtu 1300
Rgds
Alok
Chet Cronin
Level 4
Level 4
Super and thank you very much.
Have a great day.
VR
Chet Cronin
801-815-3539(USA)
Chet Cronin
Al,
I am logged in as root and in the etc folder that is no "network" folder???
Chet Cronin
801-815-3539(USA)
Chet Cronin
Hi Chet,
when you login as root run the command 'pwd'. you should see a output like this.
~ # pwd
/tandberg
if you are not in '/tandberg'  then you have to first go in that and then do the above steps.
rgds
Alok
