Showing results forĀ
Search instead forĀ
Did you mean:Ā
Spark room kit - is it possible to connect two touch screens 10" to one device at once?
Shy Solenko
there is any option to connect 2 cisco touch screen 10" to the room kit?
the table in the room is big and the client think to our 2 touch screens on the table
thansk
shy
Patrick Sparkman
Similar question came up regarding the SX80, see sx80-and-dual-touch-10, and since the Spark Room Kits run CE software it should be possible.  However using more than one Touch 10 with a codec isn't officially supported by Cisco.
Yes, you can.  However, you have to factory default the unit (if already registered via Spark).  Then add as many Touch10s needed and point them all to the IP of the CODEC.  PITA that you have to reset, but it can and has been done on my SX10.
