SpeakerTrack 60 as invidual cameras?
andreas.deland
Hello
Is it possible to remove the cameras from the speakertack60 unit and user the cameras as standalone?
//Andreas
lawrencecj
Yes you can remove the cameras from the ST60 chassis and wire them to be used as individual cameras. If you do that I don't believe it will be supported if you have any problems.
TheTechCatalyst
You may need a different power adaptor for the camera stand alone its worth mentioning...
