06-09-2020 02:06 PM
I just upgraded my sx10 units to ce 9.10.2 5adf141d8bb 2020-04-30 and I noticed that there is an "experimental" option "UserInterface Features Call CanShowWebexJoin" that seems like it is designed to show the "Join WebEx" icon. However even though I enable it, the option does not come on. Am i doing anything wrong ? Thanks in advanced!
Solved! Go to Solution.
06-25-2020 05:42 AM
06-10-2020 06:28 PM
The Join Webex feature was only experimental and didn't work properly in some of the older versions of the software.
If you upgrade to CE9.12.3 (the latest version at the time of this post), you can Ignore the setting in the "Experimental" section and instead, the setting you are looking for is UserInterface Features Call JoinWebex: Auto. If it's set to "Hidden" you won't see the Webex icon.
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-11-2020 04:41 AM
Correct me if i am wrong but i was told by TAC that 9.10 was the latest. It also has a newer release date. They told me that sometimes different dev teams release different versions and that is way 9.12 is older than 9.10. I thought the same at the beginning that 9.12 was the latest until they told me other wise. Thank you!
06-11-2020 05:02 AM
06-15-2020 07:38 AM
That what my impression was. I just saw the release date of 9.10 was newer ( May 11) than 9.12 (Apr 28) and I found that odd.
Thank you for the clarification!
06-11-2020 05:15 AM
You want to make sure it's set to auto, but I would go back and look at cmterm-ce9_12_3-140cd8212ba.k3. It is the latest code. CE9.10 has some other issues at least for us we experienced the one issue when the endpoint is configured with a proxy for Webex edge for devices that 9.10 does not support proxy so we lost the CUCM directory function on the endpoints.
06-25-2020 05:42 AM
