SX20 and SX80 Telepresence Devices - Configuration Profiles
rhuskins
Do the SX20 and SX80 CODECs support multiple configuration profiles like the C60s?
Thanks!
Patrick Sparkman
SX20 is a Quick Set codec which means it enables video conference at a value price meant for basic conference rooms, while the SX80 is an integrators codec that can be deployed various ways meant for simple to complex rooms. The SX80 as far a inputs/outputs, sits between the C40 and C60. The SX80 can do video compositing like the C60, however there are some differences with how video compositing works if running TC and CE software.
Patrick, thanks for the info...we have a couple of segregated intranets and have always used the profile feature of the C60 to load a config based on the net present in the conference room. We're looking to do a tech refresh and the SX20 and SX80 have been presented as options...we have played with the SX80 and didn't profile option...is it still there? Thanks in advance!
Thanks for the additional info, can you give me some more information as to where you're configuring these "profiles", just so I a full understanding and see if the SX Series endpoints is capable of it or something similar.
