SX20 CUCM registration rejected
Hello guys.
I have an issue with integration SX20 TC 7.1 with CUCM 9.0
CUCM registration rejected.
Provisioning CUCM checked.
There is error in application_log of SX20:
Sep 17 21:35:30.411 a8 appl[1583]: 7219.85 PROV I: [requestItem] Requesting http://XXX.XXX.XXX.XX:6970/CTLSEPe4c722676b41.tlv, state=ProvItemCTL (CTL requested)
Sep 17 21:35:30.433 a8 appl[1583]: 7219.87 PROV I: [requestItem] Requesting http://XXX.XXX.XXX.XXX:6970/ITLSEPe4c722676b41.tlv, state=ProvItemITL (ITL requested)
Sep 17 21:35:30.444 a8 appl[1583]: 7219.88 PROV I: [requestItem] Requesting http://XXX.XXX.XXX.XXX:6970/SEPe4c722676b41.cnf.xml.sgn, state=ProvItemConfig (config requested (either full or mini))
Sep 17 21:35:30.452 a8 appl[1583]: 7219.89 PROV ERROR: [handleFailedProvRequest] http req URL=http://XXX.XXX.XXX.XXX:6970/SEPe4c722676b41.cnf.xml.sgn req status=failed: HTTP code=404
On the SX20 I can see a message from troubleshooting tab:
ERROR: Provisioning Status
Provisioning failed: Provisioning is in an error state.
What can be a reason, any ideas?
7 Replies 7
sergey_karpiy
Have you found the solution? I have this problem too
For correct sip registration SX20 you need CUCM TelePresence Room license.
In this case i made h225 gatekeeper controlled trunk.
http://www.videocentric.co.uk/wp-content/uploads/2014/01/IntegrationGuideforSCOPIAECSGatekeeperandCiscoCallManagerVersion7x.pdf
Hello, thank you, have read.
Thanks for your help, guys
Suprisingly, but i found solution in factory reset and next reconfiguration of SX20
I've run into this before.
Deleting the factory installed certs seems to resolve it.
Configuration->Security->CUCM.
Delete the ITL and CTL certs.
This worked for me, tnx.
