SX20 Dignostics failed on H323
f.mbomda
Hi to all
I have an SX20 Cisco Telepresence
Software version is: TC7.3.15.a9f4c3a
I have this issue:
WARNING: Default Call Protocol
The default call protocol is set to H323, but system is not registered on that protocol. The system may not be able to make any calls. Please either change the default call protocol, verify that the protocol is enabled, or verify the H323 configuration.
I need help please
JavidHasan
Hi ,
Login to the SX 20 web interface. Go to configuration--system configuration--network services--  and enable H323
also go to H323 configure the gatekeeper and configure the ID under H323Alias. It should work fine. Hope this helps.
Javid Hasan
Hi Bro
I want to use in standalone mode with another sx10
If you want to use in standalone mode , Change the callsetup mode to direct in the H323 configuration under system configuration. Also enable H323 from configuration--system configuration--network services--  and enable H323. Make the same config on the other SX 10. Dial using the IP and make a call. Hope this helps.
Javid Hasan
Hi f.mbomda ,
Did you give a try ?
Did it work for you ?
Javid Hasan
