SX20 IP Assignment
pramod
Recently i have installed SX20, with static ip address, but it's always taking IP via DHCP, I dont know why this behaviour !!! Any solution?
Rgds,
K G
Patrick Sparkman
Have you verified it's set to static and then tried to restart the codec?  I know sometimes in the past, even though you set it to use a static address, it sometimes needs a restart for it take effect.
i tried to restart but always coming back with dhcp ip. it look very strange
Hi I have exactly the same problem.
did you manage to solve it?
thanks,
Davide
philekiert
This is a bit of a long shot but I don't suppose you're hooked up to TMS or anything that might be reapplying a template of settings each time?
Edit: Sorry! Just realised this was 6 months ago! What was the solution in the end?
