SX80 Red Screen on HDMI Input From PC
Ryan_Ingoglia
I have a room that has an integrated system primarily using AMX products.  Recently when one of the PC's running Windows 10 is selected, the screen briefly shows the computer then entire screen turns dark red when viewing it through the codec.  This PC works fine when routed directly to the monitors and another PC in the room works fine when routed to the monitors or through the codec.
I conclude that it has to be something with this computer, but I have tried various resolutions and refresh rates, but nothing worked.
Can anyone shed any light on this?
Are you sure it's not a cabling fault.   If you put another screen in place of the DX80 do you still see a red image?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
