Telepresence Touch 10 with SX10
carlos.pruna
I have a Cisco Telepresence Touch 10 Model TTC5-09, and I want connect it with a Cisco Telepresence SX10. If this is possible because I am getting this message Unsoported configuration:  The target system does not support this touch panel.
Any idea about this
Thanks in advance
Tianjun Zhou
What`s the software version of your SX10? The new Touch 10 requires minimum version CE8.3.3 OR CE 9.1.1.
->ce software release note->Cisco TelePresence Touch 10 hardware dependencies
Anurag Srivastava1
Touch 10 is supported with SX10. what is the SX10 software version?
Please see the below release notes-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/release-notes/ce-software-release-notes-ce9.pdf
Please check the hardware version for touch 10 and update your unit accordingly.
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
