TMS pop-up window
a.klessa
I am looking for a possibility to add some pop-up window to the main TMS page.
I would like to place in a pop-up window some Announcment for users.
so it should appear just after the user get logged in to TMS.
is it possible to change the main web page?
best
Aleksander
Magnus Ohm
Hi, if you enable the banner under admin tools -> config -> general settings. You can enable a popup with some information right after the user has logged in.
You do this from the tms
Web interface.
/Magnus
Magnus Ohm
Web interface.
/Magnus
thanks a lot.
works fine for the main page.
what about the TandbergScheduler web page?  is it also possible the display some info?
Aleksander
