TMS Software Directory on Shared Drive
Patrick Sparkman
Is it possible to point the TMS software directory to a shared drive?  For example, if you have a cluster, pointing all the server peers to a single shared drive would be easier than managing the directories individually on each server.
I looked at TMS Tools, however it only gives you the option to choose a directory on the TMS server.  What about creating a virtual directory in IIS, or some other method?
Wayne DeNardi
I haven't tried it myself, but I'd have thought you could use a Symbolic Link to re-direct that folder elsewhere.  Check out the "mklink" command and How to Create Symbolic Links to Shared Folders.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
