Is it possible to point the TMS software directory to a shared drive? For example, if you have a cluster, pointing all the server peers to a single shared drive would be easier than managing the directories individually on each server.
I looked at TMS Tools, however it only gives you the option to choose a directory on the TMS server. What about creating a virtual directory in IIS, or some other method?
