TMS SSO Configuration for WebEx - "Connection failure"
cwade23
Greetings
I am getting a connection failure when I configure TMS SSO. All of the backend WebEx site work has been completed including partner delegation.I have uploaded the certificate onto TMS without issue (including password). What I am a little confused with is the following:
Partner Name
Partner Issuer
SAML Issuer
I think I have all of this but something still isn't correct. The error states that the "verify partner name is correct and WebEx site allows SSO"
The partner name I believe is correct and what more is needed on the webex site?
Patrick Sparkman
Take a look at the "Configuring Single Sign On in TMS" section of the CMR Hybrid Configuration Guide starting on pg 132. Verify you've setup everything as it should be.
