TMSXE and TMS "default setup buffer"
TMS: 14.3.1
TMSXE: 3.1.2
Although we have setup in the TMS the "default setup buffer" to 10 mintes, we are not able to start meetings in advance. Looking at the documentation it says:
"Caution: Do not enable setup and teardown buffers if using Smart Scheduler, Cisco TMSXE, or any other application that makes use of the Cisco TelePresence Management Suite Extension Booking API, as the API does not support these buffers."
So if this is true, how can we setup the TMS/TMSXE to allow meetings to start in advance ?
Kjetil Ree
Hi Matthieu,
You cannot currently set up TMS to start conferences in advance if you schedule through TMSXE/Exchange.
This will change in a future release though, see the TMS 14.3.2 Release Notes page 48.
Kjetil
Kjetil Ree
Hi Matthieu,
Kjetil
Thanks for the information.
Do you have any idea about what version this change will be available and when this version will be released ?
Coming in the next feature release. Due out Q214 (calendar year).
