Touch 10 Physical buttons
bmillsapp
Does anyone know of a way to disable the physical volume and microphone buttons on the Touch 10 in a Room Kit Plus or at least not adjust the volume of the codec? We want the user to adjust the volumes from a Panel Page onscreen which will control an external DSP.
Best case would be to use the volume up/down to adjust the DSP instead of the codec.
Wayne DeNardi
There is no way to disable the physical buttons.
You could however have a macro running (see the room customisation guide) which looks for volume changes and then set the volume back to your required level.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
