touch panel cable not long enough
I have a customer with an MX800 with a CAB-DV10-12.5 touch panel cable but he say it is a bit short do you have a shorter cable that can be attached to this cable to give them more length if so what is that cable and do I need an adapter to attach them.
Thanks Scott MacDowell <smacdowell@yorktel.com>
Patrick Sparkman
You can use any standard cat5e cable to extend the supplied Cisco cable, you'd have to use a female-to-female RJ45 connector to connect the two cables.  Another option would be to use a cat5e cable that is long enough for the total length you need instead of using the supplied Cisco cable.
Thanks Patrick
