08-30-2011 04:09 AM - edited 03-17-2019 10:27 PM
Hi all,
I'm trying to pair a touch panel with a Cisco C20 and Cisco 40 but during paring procedure the touch panel display show the following error message:
Failed to extract /upgrade/pkg
The touch panel is connected over LAN and paired with a Cisco C20/C40 with software version: TC4.2.0.260857; I also try to connect directly the touch panel with the second ethernet port of C40 but I receive the same error message during the upgrade procedure.
Stefano
08-30-2011 05:00 AM
Hi Stefano,
Please, create a service request for this issue.
Thomas
08-30-2011 05:03 AM
Hi Thomas,
thank you for your answer; I'm waiting for the service contract number in order to open a service request.
Stefano
09-19-2011 11:50 AM
did u ever get a answer on this..im having exact same problem..my codec is fine but touchpanel wont upgrade
09-19-2011 10:29 PM
Hi all,
I faced same problem and opened a case. TAC suggested bring back the software version of the codec to TC 4.1.0 and reboot the panel.
To factory reset the touch panel:
I still have same upgrade problem after these steps. so TAC have offered to RMA faulty unit.
09-20-2011 07:35 AM
All,
Please post the S/N of your TelePresence Touch panel, there are some known defective panels.
Justin
10-05-2011 01:28 PM
Where can I find a list of SNs for Touch panels that may be defective? I have this situation as well.
10-10-2011 04:22 PM
Hi Guys,
Has anyone seen anything from Cisco as to how to identify which units are subject to these faults? I have a few that are failing in the same way and need to work out how hard to push for RMA.
Cheers,
Ben.
10-11-2011 09:13 AM
Ben,
What problem are you having with your TelePresence Touch 8" models?
I can verify if the S/Ns are on the list or not, but cannot post the entire list.
Justin
08-17-2012 10:24 AM
hi,
this is Chetna and I am a Cisco Tac engineer.
i would like to inform you thar there is a list of defectove touch panels which is being released by cisco, as they had a batch of faulty touch panels that shpws the same erroe and they can easily be replaced if you have the serial number and for this you need to open a service request with cisco.
08-18-2012 09:54 AM
Hi Stefano,
Please refer to the following link in order to check the affected touch panel
http://www.cisco.com/en/US/ts/fn/634/fn63448.html
Ravi
