Trying to combine 2 rooms using 2 Codec Pro's.
Jogesh-Rai2
We are using 2 codec pro's and trying to sue them in our board room which is split using a wall. We have planned to use the codecs in a combined room solution where both the codecs will communicate with each other and one will be a primary and other will be a secondary. We will call through primary codec and Quadcam feed and mic of both the codecs will work. Below is the solution/ macros provided by cisco which does not seems to be working as of now.
https://github.com/gve-sw/gve_devnet_n_way_divisible_conference_rooms_webex_devices_macros
I have followed it completely and ran the macros on the codecs, but Quadcam feed of both codecs and Mics are not working.
Any help or further suggestion will be highly appreciated.
videoalchemy
hi @Jogesh-Rai2 , were you able to sort this out in the end?
looking to do something similar and curious about learnings from your environment. thank you!
