USB-C pass through not getting detected
Parvez2227
Hi all,
Can you help me out.
I am facing problem while connecting USB-C cable to my Lenovo M720Q desktop,
Showing Display connection might be limited on my desktop, while I have upgraded all drivers for audio, video and usb as well on my desktop
I can see on device management l, it's showing desktop camera and speaker but screen is not getting on deskpro.
And there nothing happening on deskpro
Sunny Khandale
For extension of display to the Webex Desk Pro your Computer must support Alt-mode Display Port(This is mentioned in the data sheet for Webex Desk Pro "USB-C BYOD" section). https://www.cisco.com/c/en/us/products/collaboration-endpoints/webex-desk-pro/datasheet-c78-743105.html
Which I believe is not supported on the desktop model you mentioned.
Next to the ports of a PC are symbols / logos, which indicate what you can do with the port.
  1. Is there a symbol of a lightning (Thunderbolt 3) next to the USB C port? Then you can charge via this port and pass on a video signal and thus connect a monitor. This port supports DisplayPort alt mode.
  2. Is there a symbol of a D (DisplayPort) next to the USB-C port? Then you can pass on a video signal via this port and thus connect a monitor. This port supports DisplayPort alt mode.
  3. Is there a symbol of a battery next to the USB C port? Then you can charge your laptop via this port. This port does not support DisplayPort alt mode.
Thanks @Sunny Khandale
As @Sunny Khandale indicated in his reply, your Lenovo M720Q desktop PC only has SuperSpeed (SS) USB-C ports on it, not any that will support Display Port, so it will not work.  You will need to change your PC to one that supports USB-C DisplayPort Alternate Mode if you wish to use the DeskPro as monitor/camera/speakers for your PC.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
