VCS backup
Louis-Alex
Is there a CLI command I could use on my x8.7 devices to create backup files (exactly as if use the Backup and Restore menu under Maintenance) ?
Patrick Sparkman
Backup and restore must be done using the web interface, there is no API commands for this process.  The VCS Admin Guides has API reference chapters that list all commands based on type: xConfiguration, xCommand, and xStatus.
Yeah, that's what I thought ...
My reads was suggesting that too, but I was hoping to forgot somethin' :-P
...trying to automate backups with python... I'll try something else :-)
Thanks Pat :-)
Hello Louis-Alex,
You have found a solution to program a schedule backup for Expressway ?
i tried to find a cli command that generate backup files but it seems not possible.
Asma
