VCS C VCS E Replacing the sender number
twiesboeck
I m using a configuration with an VCS-C and VCS-E.
The customer has an internal and an external video domain.
So for incoming calls the transform pattern on the VCSE works fine.
But how can i translate the calling number from a internal located codec,
to call outside videostations, that the can be called back.
So my internal codecs are registered at:  xxxx@internal.com
so when i Call an external client i see as calling number: xxxx@internal.com
So i need to change my calling number for all internal clients when the are calling external ones
from xxxx@internal.com to xxxx@external.com.
VCS-C and VCS-E is runnning on Version 7.1.
Best Regards
Thomas
Haydn von Imhof
Level 4
Level 4
You can do this in a CPL script.
Below is one i am using for a single system.
If i call an external client from test@internal.com they will see the call return address as test@external.com
http://www.tandberg.net/cpl-extensions" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:cpl cpl.xsd">
test@internal.com">
test@external.com">
Thanks for the Info.
But i think ill need the 7.2 Sw Version on the VCS for using this CPL file.
If this will work,  then my next question:
is it possible to use a variable instead of "test".
Or do i have to create 1 CPL File for each endpoint.
Best Regards
Thomas
Correct, the replace source alias by using CPL is newly supported feature introduced from X7.2 software release on VCS.
The source replace feature by using source-url-for-message in X7.2 software release only support fixed string not a regex format.
Therefore currently doesn't support to configuring ”(.+)@internal\.com” to ”\1@external.com" while VCS is running with X7.2.
We are looking for enhance this feature in X78.0 release include for supporting regex format for source URL replacement.
