VCS Clustering failing from time to time Error message Failed - This peer either has a different list of peers or it has a different software version installed
mguguvcevski
The following error message appears after some time in a cluster with only two VCS Controls:
for the remote peer.
A restart of the slave solves the issue.
Has anyone come across this ?
16 Replies 16
Yes, every port both UDP and TCP. I do not see it as a security issue, as it is defined precisely between two filtered IPs.
OK, Thanks.
Best regards.
