08-10-2012 08:50 AM - edited 03-17-2019 11:35 PM
I logged into my VCS-Expressway after performing the x7.2 update, and have come across a new warning I had not seen before. It states:
1 alarm: * warning Insecure password in use - The root user's password is hashed using MD5, which is not secure enough
I've looked around in the documentation, and have not found anything that mentioned this. Is it a matter of just resetting the password, which is already very strong, or is there something else I need to do to remove this alarm? Any ideas?
Michael
Solved! Go to Solution.
08-10-2012 09:26 AM
Hi Michael,
Thats a wraning generated as you are still using the default root password on expressway!!
a snippet from the document!!
An “Insecure password in use” alarm will be raised against the root account. This is because the VCS now uses SHA512 to hash passwords. Passwords were previously hashed using MD5. The root account will still be accessible but you are recommended to use the root passwd command to reset the root account password. Administrator account passwords are rehashed automatically on upgrade.
check below document for more details
page 7 has after upgrade information.
change the password for root!!
I hope it clarifies your doubt
Alok
08-10-2012 09:26 AM
Hi Michael,
Alok
08-10-2012 09:31 AM
I just confirmed that I am not using the default password for my Expressway. Your message did help though, I needed to re-run the passwd command on the VCS to re-hash the password in SHA512. Thanks.
08-10-2012 12:49 PM
Michael
Thanks for posting that. That clarified why I too was seeing the same alarm on my development VCS where I also am not using the default pw.
03-17-2018 06:52 PM
| Insecure password in use | The admin user has the default password set | Raised | Warning | This system | Change the admin password |
When i click on change the admin password link:
Administrator accounts
Prohibited access: Page not accessible to 'Read-only' users |
How can i change "Read-only" users to "Read-write".
Shweta
03-19-2018 02:31 PM
Login to the VCS with the default admin account, which has read-write access:
You can then change the password under Users > Administrator Accounts.
08-12-2012 05:02 PM
You can find same information at page 66 of TelePresence VCS X7.2 Introduction presentation, https://supportforums.cisco.com/docs/DOC-26316 as well.
