Video Codec Basic question
twissam
I am little bit confused, I have VT advantage A connected to an IP phone A with another IP phone B and VTA B.
When they are both IP phone in the same region, if i put the Video call to 50 Kbp, the video will still work between bot of them.
when i create a region and enable bandwidth for less than 384 between both location the call will be voice instead of video as there is not bandwidth enough.
I am confused, what is the bandwidth needed for the VTA and how can i limit it on the WAN using location.
Good day
ivillegas
Level 6
Level 6
Around 380kbs could be fine with the video. I think you need to have QOS applied to the interface so that bandwidth issues can be overcome.
gajolly
as mentioned in previous post 384 will be good enough however please take layer2 + layer3 headers in consideration
hth...
