04-08-2013 08:27 AM - edited 03-18-2019 12:54 AM
I've a problem with video calls in my environment. I used CUBE between two different IP telephony networks. There are SIP Trunks between Call Managers and CUBE. For audio it works fine, but for video I have an interesting problem. Architecture is like this:
IP PHONE (9951) --> CUCM (7.1.5) <---SIP TRUNK ---> CUBE <--- SIP TRUNK ---> CUCM (7.1.5) <--IP PHONE (9971)
When 9951 calls 9971, 9951 sends and receives video but 9971 only sends video and discards the receiving video packets. For the other way around when 9971 calls 9951, this time 9971sends and receives video but 9951 only sends video and discards the receiving video packets. In short calling party sends and receives video but called party only sends video and discards receiving video.
Do you have any idea what might be causing the problem?
Also in this scenario:
IP PHONE (9951) --> CUCM (7.1.5) <---SIP TRUNK ---> CUBE <--- SIP TRUNK ---> CUCM (7.1.5) <--IP PHONE (7985)
There is only audio, no video. Do I have to configure something for SCCP on CUBE? Do you have any idea?
Thank you.
Solved! Go to Solution.
04-08-2013 10:16 AM
Hello
please find the below
You have to use "sdp pass-through" the basic video calls will work . Make sure that the calls (SIP to SIP) because if you use (SIP to H323) it will not work. kIndly find the below
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_9320.html
I think also you have to configure transcoding
Thank you
please rate if this will help
04-08-2013 10:16 AM
Hello
Thank you
04-15-2013 05:00 AM
Thank you islam.kamal,
Now it is working fine between 9951 and 9971.
But I still have a problem with the 7985:
Regards.
Fatih
05-15-2013 07:04 AM
When I turn the "IP Voice Media Streaming App" off, 7985 model phones are able to make video calls in this scenario. But this time they can't make any conference in their own network since turning that service off causes the software conference bridge stop in CUCM.
So, I tried another way. I turned the "IP Voice Media Streaming App" on again, then under CUCM Administration -> System ->Service Parameters, I chose Cisco IP Voice Media Streaming App and set the value of Media Termination Point (MTP) Parameters -> Run Flag to false.
For the momemt it is working fine. I am not sure if I will still need that service if I have a hardware conference bridge.
Fatih.
