Video Surveillance IP
pprender29
My company is looking to install Cisco Surveillance cameras, part of the implemenation and setup is to configure QOS and Multicasting on our Network. we are using 3560's along with a 4510 core switch. On the 3560's is it enough to configure the port that the camera will connect with mls qos trust dscp and apply the same command to GIG port which connects back to the Core Switch. On the GIG port on the 4510 configure it with qos trust dscp. In relation to the Multicasting iam not sure where to start so any help is appreciated.
3560
Int fa0/10
des Cisco Video Surveillance IP Camera
switchport mode access
switchport access vlan 40
switchport port-security
switchport port-security mac-address sticky
switchport port-security maximum 1
switchport port-security violation shutdown
mls qos trust dscp
spanning-tree portfast
spanning-tree bpdufilter enable
load-interval 60
interface GigabitEthernet0/1
switchport trunk native vlan 128
switchport mode trunk
switchport nonegotiate
udld port
mls qos trust dscp
storm-control broadcast level 10.00
end
QoS is enabled
QoS ip packet dscp rewrite is enabled
4510
interface GigabitEthernet9/18
qos trust dscp
udld port
end
QoS is enabled globally
IP header DSCP rewrite is enabled
carunach
This should be sufficient for video traffic classification but we will need to enable Priority queuing for egress traffic.You should also configure the Camera to set the correct DSCP for video traffic (DSCP 40). If there are WAN links between the viewer and camera, QoS needs to be enabled across WAN.
Please take a look at the Implementation section in IP Video Surveillance Design Guide
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/Video/IPVS/IPVS_DG/IPVSchap6.html#wp1058136
For generic multicast information, please refer the following url(s) :
http://www.cisco.com/en/US/tech/tk828/tk363/tsd_technology_support_sub-protocol_home.html
http://www.cisco.com/en/US/customer/tech/tk828/technologies_tech_note09186a0080094821.shtml
