Dear all, let me explain my scenario.
A user has one extension (1000) and 02 phones (9951 SIP and a 7921 SCCP Wireless).
We're trying to find a way in which we could use the same extension on both phones.
OK, at least until writing this one, we couldn't find any way to share it in a perfect way.
Both SIP/SCCP could register into CME, however calls rings only on SCCP, so we decided to find a workaround using hunt-group.
Follow my config:
voice register dn 1
number 1001
name 1001
mwi
voice register pool 1
id mac xxxx.yyyy.zzzz
type 9951
number 1 dn 1
dtmf-relay rtp-nte
username 1001 password cisco
description 1001
codec g711ulaw
no vad
camera
video
ephone-dn 1 dual-line
number 1002
name 1002
ephone 1
device-security-mode none
mac-address aaaa.bbbb.cccc
type 7921
button 1:1
voice hunt-group 2 parallel
pilot 1000
list 1001, 1002
Results:
If someone tries to reach the user by the pilot number (1000), both numbers (SCCP and SIP) rings simultaneously…..perfect.
Voice calls works great, but, if someone using another 9951 (video enabled) tries to reach the pilot 1000 and the SIP phone (number 1001) answer the call…..I get no video on the call, only audio.
I've replaced the SCCP phone for another SIP, just to be sure that there's nothing related to the hunt-group….and it has worked well.
For some reason, if the SCCP is registered and available on the hunt group…..the video call doesn't work when dialing to the pilot number.
Any ideas would be helpful.
Leandro
