05-23-2005 07:42 PM - edited 03-17-2019 08:27 PM
Is it possible to forward an incoming call from ptsn
to another number on pstn?I am using as5350.How do I
setup pots dial peer to achieve this?Thanks.
05-25-2005 02:20 AM
Yes, TDM hairpinning is definitely possible on Cisco voice gateways. I have done it without any problems.
As far as I remember, you have to make sure that the IOS supports TDM hairpinning.
Then just configure two POTS dial-peers - one for incoming calls only and one for outgoing calls only.
You have to use direct-inward-dialing.
07-17-2005 10:14 AM
You can use the num-exp command. This is the most simplest way to achive what you are asking for.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4224/sw_confg/voipconf.htm#11393
