WEB BRIDGE DNS FAILURE
Chet Cronin
Level 4
Level 4
THE Certs are kicking my butt.  Sorry I am a rock.
Ok I created the .key and .CSR and submitted the CSR to my CA.
I got back the CA and uploaded via WINSCP the  CA with .CRT extension.
Webadmin = .key and .crt
Callbridge = .key and .crt
Webbridge = .key and .crt
XMPP = .key and .crt
Now what I think I did right was the bundle.crt ???   I put the CA first and the Root CA1 and CA2 second in the .CRT bundle file
Now I get in the status on CMS the join.example.com URI (DNS Failure) ???
I pointed the join A record to the IP of interface A  ???
I created the SRV records also ..
Also when I browse the join.example.com using chrome I get the Meeting APP but only a sign in and not a join button ??
Chet Cronin
Anurag Srivastava1
Hello Chris,
If only sign in option is coming that means you have not posted the join url under webbridge
you can do it via web gui under configuration --> general--webbridge settings
also you can do it via api via posting a new webbridge with a join url.
Also make sure you have _xmpp-client SRV r?
if DNS is failing you can try command
dns lookup A join.example.com and see if it is resolving to IP or not?
if not try dns flush if you are sure that you have made the join A record.
Please rate if it is helpful and mark as accepted solution if applicable....
I added the following information in the CMS via the browser. Don't have postman so I can't use the API format .. Not sure how to manually build an api script without using postman. Web Bridge Settings: Guest URI: https://join.example.com Guest accout JID domain: example.com Guest access vai ID and passcode: secure: require passcode to be supplied with ID Guest access via hyperliinks: allowed User sign in: allowed IVR: 6983319999 joining scheduled lync conferenced by ID: not allowed External access Web Bridge URI: https join.example.com IVR telephone number 6983319999 ------------------------------------------------------------------- I think I found the problem .. please confirm and what would be the correction if I need to fix it. The SRV records _xmpp-client._tcp.example.com pointing to xmpp.example.com port 5222 _xmpp-server._tcp.example.com pointing to xmpp.example.com port 5269 So the join.example.com would not work ... I modified the CMS and replaced the join URI with the XMPP and still the same problem .. the Join option doesn't show up in the Meeting APP from the browser ??
Chet Cronin
Hello Chet,
You don't need a _xmpp-server srv here
you can refer the below link-
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/213821-configure-and-integrate-cms-single-combi.html#anc12
Please rate if it is helpful....
