xStatus not working on SX20
graysontopping
Community Member
I am having an issue running xStatus commands from the sx20 web interface.  I keep getting a message saying the command was rejected. I am able to run xCommand and xConfig without issue.
Has anyone else run into this?
It looks like the web interface only takes xCommand and xConfiguration inputs. I usually just open /status.xml and search for what I need.
graysontopping
Community Member
BTW,  This is happening on all of our codecs, not just one
This was the answer.  Not sure why they would block or not support xStatus from the web interface.  I went through and SSH connection and didnt have a problem
Only xCommand and xConfiguration is supported via the API page of the web interface.  If you want to get xStatus values, there are links to the XML files of the x API commands (configuration, status, command) on the same page of the web interface.
