CMS stream to YouTube does not work directly or through WOWZA
alexniko
I have a problem to setup streaming from conference. What is done:
Cms cluster
Cms01 172.17.16.204
Cms02 172.17.16.206
Cms03 172.17.16.206
Cms streamer
Cmsstr - 172.17.16.223
Cms cluster licences
Feature: callbridge status: Activated expiry: 2120-Feb-10 (36367 days remain)
Feature: turn status: Activated expiry: 2120-Feb-10 (36367 days remain)
Feature: webbridge status: Activated expiry: 2120-Feb-10 (36367 days remain)
Feature: recording status: Activated expiry: 2120-Feb-10 (36367 days remain)
Feature: personal status: Activated expiry: 2120-Feb-10 (36367 days remain)
Feature: shared status: Activated expiry: 2120-Feb-10 (36367 days remain)
First I setup CMS 2.9.2 as streamer
cmsstr> streamer
Enabled                 : true
Interface whitelist     : a:8445
Key file                : cmsstr.key
Certificate file        : cmsstr.cer
CA Bundle file          : chain-n.cer
Trust bundle            : cms123n.cer
Add streamer to CMS cluster
<streamers total="1">
    <streamer id="594c821f-a0e1-4c3f-b26a-7fd1907c6605">
        <url>https://172.17.16.223:8445</url >
    </streamer>
</streamers>
Create callProfile
<callProfile id="291b770c-9ed6-4ba7-8ba6-dbc4bae3955f">
    <recordingMode>manual</recordingMode>
    <streamingMode>automatic</streamingMode>
</callProfile>
Create CallLegProfile
<callLegProfile id="8ce8e5ab-0cf1-40c3-b25b-5baf8a1be4ba">
    <defaultLayout>telepresence</defaultLayout>
    <presentationContributionAllowed>true</presentationContributionAllowed>
    <presentationViewingAllowed>true</presentationViewingAllowed>
    <muteSelfAllowed>true</muteSelfAllowed>
    <videoMuteSelfAllowed>true</videoMuteSelfAllowed>
    <changeLayoutAllowed>true</changeLayoutAllowed>
    <streamingControlAllowed>true</streamingControlAllowed>
</callLegProfile>
Create DTMF profile
<dtmfProfile id="9e5c4b8e-1102-4518-b3b7-2924fc01a5e3">
    <muteSelfAudio></muteSelfAudio>
    <unmuteSelfAudio></unmuteSelfAudio>
    <toggleMuteSelfAudio></toggleMuteSelfAudio>
    <lockCall></lockCall>
    <unlockCall></unlockCall>
    <muteAllExceptSelfAudio></muteAllExceptSelfAudio>
    <unmuteAllExceptSelfAudio></unmuteAllExceptSelfAudio>
    <endCall></endCall>
    <nextLayout></nextLayout>
    <previousLayout></previousLayout>
    <startRecording>**7</startRecording>
    <stopRecording>**8</stopRecording>
    <startStreaming>**5</startStreaming>
    <stopStreaming>**6</stopStreaming>
    <allowAllMuteSelf></allowAllMuteSelf>
    <cancelAllowAllMuteSelf></cancelAllowAllMuteSelf>
    <allowAllPresentationContribution></allowAllPresentationContribution>
    <cancelAllowAllPresentationContribution></cancelAllowAllPresentationContribution>
    <muteAllNewAudio></muteAllNewAudio>
    <unmuteAllNewAudio></unmuteAllNewAudio>
    <defaultMuteAllNewAudio></defaultMuteAllNewAudio>
    <muteAllNewAndAllExceptSelfAudio></muteAllNewAndAllExceptSelfAudio>
    <unmuteAllNewAndAllExceptSelfAudio></unmuteAllNewAndAllExceptSelfAudio>
    <getTotalParticipantCount></getTotalParticipantCount>
</dtmfProfile>
Instal Wowza server on Linux (172.17.16.230) . Add Source Authentication username - cms, password cms.
  1. Add stream target YOUTUBE
Source Stream Name - CMSSTREAM
Destination Application Name - live2
Destination Application Instance - CMSSTREAM
Destination Host - a.rtmp.youtube.com
Destination Port  - 1935
Destination Stream Name  - YouTube translation key
User Name - fcbrn.ru@gmail.com
Password - password of Google account
  1. Add streamURL in coSpace that need to be streamed
   <coSpace id="bbcb4043-6f10-4d3c-8358-aca0e94ea534">
       <name>Conf10-stream</name>
      <autoGenerated>false</autoGenerated>
      <uri>meeting10s</uri>
      <callId>77750</callId>
      <streamUrl>rtmp://cms:cms@172.17.16.230/live/CMSSTREAM</streamUrl>
      <secret>qzihD0_VhBcC9TDB8lU0xQ</secret>
</coSpace>
There is no broadcast on YouTube. Testing on a local network using VLC at https: // cms: cms@172.17.16.230: 1935 / live / CMSSTREAM the connection is established no more than 10-15 seconds after which it is interrupted, the connection with the broadcast is very slow, sometimes it shows only a gray or black screen and sound with a delay of more than 30 seconds.
If a link to YouTube in coSpaces is a  direct link in the format rtmp: //a.rtmp.youtube.com/live2/ the broadcast key, the transmission is regularly interrupted, very long delays or immediately interrupted with an error
In the logs of the CMS on which the conference is hosted, there are a large number of warnings:
streaming 492: streaming poll failed, 2-3 times per minute.
The following entries in the event log
call 204: configured - API call leg 73927a07-db2c-4efe-85a9-c39355990659
participant "guest2554166268@fccps.local" joined space bbcb4043-6f10-4d3c-8358-aca0e94ea534 (Conference # 10 (stream))
participant "guest2554166268@fccps.local" (73927a07-db2c-4efe-85a9-c39355990659) joined conference 23eff47b-b9f3-4511-ac4b-374e16cc9fca via XMPP
streaming device 2: available (1 streamings)
Conferences, calls from devices, jabber, webRTC, recording and everything else works fine.
Can you help me out
0 Replies 0
