04-13-2015 04:35 AM - edited 03-18-2019 04:19 AM
I've deployed TMS 14.6.1 & TMSPE v1.4.
In TMS > Admin Tools > Provisioning I've adjusted "AD Filed Mappings for New User Imports" the file "Office Phone" to "ipPhone".
when I import users and I check for a imported user (Toggele Details) the Office Phone is still mapped to "telephoneNumber"...
Is this a known problem?
rgds, Geert.
04-13-2015 09:37 AM
Did you restart the TMSPE service after you made the change, it's required to restart the service after any PE setting has been changed.
My lab environment is down at the moment, so I can't check.
04-14-2015 12:04 AM
Yes, I did restart the tmspe service.
04-14-2015 01:40 PM
I did a test and swapped the the "telephoneNumber" and "mobile" fields, and after I restarted the PE service and did another user import, the fields were swapped in the user's profile. It didn't update any users right away, it was when I re-saved the AD configuration and performed another import, that it updated all the users with the changed fields.
