I have a client that needs the following cable replacement for a TX9000 telepresence system.
37-1335-xx CABASY,WIRE HARNESS,DP-DP,NON-STND,1.5m
The cable is part of the TS1 codec pack.
From the Cisco Partner Helpline the answer was that the cable is not orderable through CCW.
I would appreciate if anybody can tell me what to do in this situation or if I can buy the cable somwhere or with the pinout or the connectors do it.
I can't tell the client to buy another TX9000 because I can't order the cable.
Thank you very much in advance.
Eduardo Tapia V.
