MX700 kernel: loop: Write error
daniele.monni1
One of my mx700s during the call does not receive or send more audio even if it is not lost.
In log peripherals.log I found this error repeated
2017-04-26T15:45:44.147+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: loop: Write error at byte offset 8457216, length 1024.
2017-04-26T15:45:44.147+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: Buffer I/O error on device loop3, logical block 8259
2017-04-26T15:45:44.187+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: lost page write due to I/O error on loop3
2017-04-26T15:45:44.187+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: loop: Write error at byte offset 8460288, length 1024.
2017-04-26T15:45:44.187+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: Buffer I/O error on device loop3, logical block 8262
2017-04-26T15:45:44.187+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: IO error syncing ext2 inode [loop3:00000812]
2017-04-26T15:45:44.237+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: EXT2-fs (loop3): previous I/O error to superblock detected
2017-04-26T15:45:44.237+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: loop: Write error at byte offset 1024, length 1024.
2017-04-26T15:45:44.237+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: Buffer I/O error on device loop3, logical block 1
2017-04-26T15:45:44.237+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: lost page write due to I/O error on loop3
2017-04-26T15:45:44.237+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: EXT2-fs (loop3): error: ext2_free_inode: bit already cleared for inode 2066
2017-04-26T15:45:44.266+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: loop: Write error at byte offset 8457216, length 1024.
2017-04-26T15:45:44.266+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: Buffer I/O error on device loop3, logical block 8259
2017-04-26T15:45:44.266+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: lost page write due to I/O error on loop3
2017-04-26T15:45:44.000+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 ntpd[2554]: frequency file /config/ntp/drift.TEMP: Input/output error
2017-04-26T15:45:49.157+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: loop: Write error at byte offset 2048, length 1024.
2017-04-26T15:45:49.157+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: Buffer I/O error on device loop3, logical block 2
2017-04-26T15:45:49.172+00:00 SalaPresidenteLitta E4:AA:5D:A2:53:C1 kernel: lost page write due to I/O error on loop3
Do you think a firmware recovery can be useful or is there any other problem?
Has anyone ever happened?
Daniele
Elias Sevilla Duarte
From the logs, the issue seem to be memory related.
Try upgrading the software, it will most likely resolve the issue. It is also worth to try a factory reset.
If the above suggestion does not resolve the issue, I would suggest opening a TAC case, as they may have a fix for that.
