Switching between TC and TCNC (Encrypted and Non-Encrypted)
David Anstee
Level 4
Level 4
Is it possible to change between TCNC and TC firmware versions on the CIsco SX20?
SW Image Non-Encrypted SX Series
SW Image Encrypted SX Series
We have a Cisco SX20 pre loaded with TCNC, but want to put TC firmware on.
Is this possible?
Martin Koch
should work to upload it, but you need to have the proper license key to get it to work.
I did not try it with >6.2 where "any key" works, but I would expect it to work with the proper key type: TC vs TCNC.
If the webinterface does not allow you to upload the TC software you would need to do some tricks, but it should
be possible.
If you boot up from TC to TCNC remember to check that telnet and http are enabled,
if not you might lock yourself out as https and ssh are not working on the TCNC and you would need
a serial connection which would require either a usb to serial or a y-cable, ...
If you do not have the TC license you would have to contact your Cisco Partner / Cisco and ask
if its possible, I never tried that, if you do so give us a feedback here how it went!
Please remember to rate helpful responses and identify helpful or correct answers.
