Alerts creation for DNS failures
yuricyrino
We've gor some internal DNS servers, the point is how to create DNS Trace for internal sites
Tyler Langston
Hi @yuricyrino - I ran your situation by our experts and they had some input and resources to share:
DNS Trace Tests will probe Root DNS resolvers, which require DNS records to be public, so it isn't possible to verify internal DNS records with DNS Trace Tests.
This documentation explains the test well, but the goal is to ensure that the right hierarchy is being followed, so more probing questions would be needed to find out what they'd like to gain.
If there is still a need for you to verify alert creation, I recommend working with our support team! They're quick to respond, knowledgable, and thorough. If you've never contacted them before, instructions are available here
Thanks!
