Thousandeyes Integrations
Pedroxh
Today, Thousand eyes just integrate to new devices Cat9k , N9K and a couple of routers models.
We have any prevision to integrate the solution for Cisco ACI and for old switch models (N7K,Cat3850,4500 etc) ?
Best regards
******* If This Helps, Please Rate *******
balaji.bandi
not that i am ware of that supports, since its docker support on new devices.
BB
carcerva
Hi @Pedroxh , thanks for your patience while I looked into this. I’m sorry to say there are no plans to support older device platforms at this time. Enterprise Agents run on platforms that support the containerized application framework supported by Cisco IOS XE Kernel and Cisco Application Framework and these are not part of the platforms you mentioned. We do try to provide many options to fit into as broad a range of customer requirements as possible! You can review the supported types here (Enterprise Agents installation Types), and general requirements here (Support Matrix for the Cisco Devices).
