Yuki Iwagishi
1. はじめに
IP Phone 8800 シリーズ Firmware 11.7 からUIが変更になりました。
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/firmware/11-7-1/Release_Notes/p881_b_8800-release-notes-for-1171.html#reference_9C6020BE78196F70A8F81E43A8752608
New Desktop Icons, Background, and Missed Calls Display
Firmware release 11.7(1) introduces an improved user experience with new badged icons.
If you have missed calls, the missed call icon, and a counter showing the number of missed calls, display on your phone desktop. If you receive a voicemail, the missed call icon changes to the voicemail icon and voicemail counter until you listen to your messages.
In addition, there are new icons for multiple calls. If you have more than one call on a line, either the held icon or the off hook icon change to show the number of calls.
It is now easier to see your missed calls by selecting a line key to view the missed calls for that line in the call window. The missed call counter clears when you return to the idle screen.
Your phone display is now enhanced with a new default background for your phone desktop.
また、8811/8841/8851  の3機種についてコンポーネントを変更した関係で新規出荷分からFirmware 11.7 以降の利用が必須になります。
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/firmware/11-7-1/Release_Notes/p881_b_8800-release-notes-for-1171.html#reference_A005F1E78D7783F9CBC582A1E625F8E0
New Cisco IP Phones 8811, 8841, 8851, and 8851NR Hardware
The Cisco IP phones 8811, 8841, 8851, and 8851NR has hardware updates. The new phone version IDs are:
  • Cisco IP Phone 8811: V08
  • Cisco IP Phone 8841: V08
  • Cisco IP Phone 8851: V08
  • Cisco IP Phone 8851NR: V08
Phones manufactured with the new version ID must run Firmware Release 11.7(1) or later. The phone firmware does not allow the phone to be downgraded to releases earlier than Firmware Release 11.7(1). There is no hardware upgrade for Cisco IP Phone 8861.
上記2点から、既存8811/8841/8851 ご利用の皆様に、Firmware 11.7 へのアップグレードと Phone Only Locale 11.7 のインストールをお勧めします。
2. UI の変更点
UIの主な変更点は下記の通りです。
デフォルトの壁紙が設定/ソフトキー表記の背景が白地
11.7
11.5
オンフック表示/日付が M 月D 表示。セパレータおよび年の廃止
11.7
11.5
11.7 オフフック表示
11.5 オフフック表示
発信時 グリーン表記
11.7
11.5 発信時
着信時。オレンジ色表記
11.7
11.5 着信時
通話時 グリーン表記
11.7
11.5 通話時
不在履歴カウント
11.7
11.5
ピックアップ通知
11.7
11.5
パーク押下 グリーン表記
11.7
11.5
被パーク グリーン表記
11.7
11.5
左上アイコンイニシャル表示
11.7 Line Text Labelからの左上アイコンイニシャル表示 (英字のみ)
11.7 Line Text Label 日本語表記(イニシャル表示なし)
11.7 Line Text Label スペースありの日本語表記(イニシャル表示なし)
Shu K
オンフック表示/日付が M 月D 表示  ってバグですよね
Yuki Iwagishi
お世話になっております。
日付表記ですが11.7以降 "MAR 29"(MMM DD) の形式となっております。
日本語ではMMMを x月と翻訳しています。そのため、M月 D と表示されております。
この問題に対しては ID CSCvc66832 で登録しております。
よろしくお願いします。
Yuki Iwagishi
日付表示に関して、対処方法のドキュメントが SR Collection にアップロードされました。
https://supportforums.cisco.com/ja/document/13292451
Cisco IP Phone 8800 シリーズを FW 11.7 (1) へアップグレード後、日付表示から"日"が抜ける
