Naoki Kai
例えば S1 - MME 間で問題がある場合は、上記から Protocol 81 と 82 を monitor protocol 実施時に有効にしてください。
下記は monitor protocol の出力例で 各数字が 対応する protocol 番号になります。
[local]asr5000# monitor protocol
MONITOR GLOBAL PROTOCOLS:
   11 - SNMP                                  21 - L2TP         (Admin only)
   12 - RADIUS Authentication (Admin only)    22 - L2TPMGR      (Admin only)
   13 - RADIUS Accounting     (Admin only)    23 - L2TP Data    (Admin only)
   14 - A11 (R-P Interface)   (Admin only)    24 - GTPC         (Admin only)
   15 - Mobile IPv4           (Admin only)
   16 - A11MGR                (Admin only)    26 - GTPU         (Admin only)
   17 - PPP                   (Admin only)    27 - GTPP         (Admin only)
   18 - A10                   (Admin only)    28 - DHCP         (Admin only)
   19 - User L3               (Admin only)    29 - CDR          (Admin only)
   20 - USERTCP STACK         (Admin only)    30 - DHCPV6       (Admin only)
   31 - RADIUS COA            (Admin only)    51 - SCTP         (Admin only)
   32 - MIP Tunnel            (Admin only)    52 - M3UA         (Admin only)
   33 - L3 Tunnel             (Admin only)    53 - SCCP         (Admin only)
   34 - CSS Data              (Admin only)    54 - TCAP         (Admin only)
   35 - CSS Signaling         (Admin only)    55 - MAP          (Admin only)
   36 - EC Diameter           (Admin only)    56 - RANAP        (Admin only)
   37 - SIP (IMS)             (Admin only)    57 - GMM          (Admin only)
   38 - IPSec IKE Inter-Node  (Admin only)    58 - GPRS-NS      (Admin only)
                                              59 - BSSGP        (Admin only)
   40 - IPSec IKE Subscriber  (Admin only)    60 - CAP          (Admin only)
   41 - IPSG RADIUS Signal    (Admin only)    61 - SSCOP        (Admin only)
   42 - ROHC                  (Admin only)    62 - SSCFNNI      (Admin only)
   43 - WiMAX R6              (Admin only)    63 - MTP3         (Admin only)
   44 - WiMAX Data            (Admin only)    64 - LLC          (Admin only)
   45 - SRP                   (Admin only)    65 - SNDCP        (Admin only)
   46 - BCMCS SERV AUTH       (Admin only)    66 - BSSAP+       (Admin only)
   47 - RSVP                  (Admin only)    67 - SMS          (Admin only)
   48 - Mobile IPv6           (Admin only)    68 - PHS-Control  (Admin only)
   49 - ASNGWMGR              (Admin only)    69 - PHS-Data     (Admin only)
   50 - STUN                  (Admin only)    70 - DNS Client   (Admin only)
   71 - MTP2                  (Admin only)    76 - PHS-EAPOL    (Admin only)
   72 - HNBAP                 (Admin only)    77 - ICAP         (Admin only)
   73 - RUA                   (Admin only)    78 - Micro-Tunnel (Admin only)
   74 - EGTPC                 (Admin only)    79 - ALCAP        (Admin only)
   75 - App Specific Diameter (Admin only)    80 - SSL          (Admin only)
   81 - S1-AP                 (Admin only)    82 - NAS          (Admin only)
   83 - LDAP                  (Admin only)    84 - SGS          (Admin only)
   85 - AAL2                  (Admin only)
   86 - PHS(Payload Header Suppression) (Admin Only)
   87 - PPPOE                 (Admin only)
   88 - RTP(IMS)              (Admin only)    89 - RTCP(IMS)    (Admin only)
   90 - LMI                    (Admin only)   91 - NPDB(IMS)    (Admin only)
   92 - SABP                  (Admin only)
   (B)egin Protocol Decoding,   (Q)uit,   <ESC> Prev Menu
