Ports not found
geekymutt
Hi all, first post, not that experienced with trex yet, but using it to create a ton of netflow data, can make it cooperate in a VM, boss and a dev want it on a box.
Running it on a ubuntu workstation that has 2xgbe ports and after i run the set up ports script, then try to run t-rex it can't find the ports.and
Any ideas where to look  and see what I might have messed up?
ybrustin
Hi, could you post the commands you are running and output you get?
