Question on YDK, pip, and Virtual Environments
brfoster
Team,
I'm not quite understanding something with YDK.
I created a fresh setup of YDK as shown below...
[gibson@rickenbacker PythonProjects]$ git clone https://github.com/CiscoDevNet/ydk-py.git
Initialized empty Git repository in /home/gibson/PythonProjects/ydk-py/.git/
remote: Counting objects: 4461, done.
remote: Compressing objects: 100% (12/12), done.
remote: Total 4461 (delta 5), reused 0 (delta 0), pack-reused 4449
Receiving objects: 100% (4461/4461), 67.25 MiB | 5.84 MiB/s, done.
Resolving deltas: 100% (3103/3103), done.
[gibson@rickenbacker PythonProjects]$ cd virtualenvs/
[gibson@rickenbacker virtualenvs]$ virtualenv -p python2.7 ydk-py-venv
Already using interpreter /usr/bin/python2.7
New python executable in /home/gibson/PythonProjects/virtualenvs/ydk-py-venv/bin/python2.7
Also creating executable in /home/gibson/PythonProjects/virtualenvs/ydk-py-venv/bin/python
Installing setuptools, pip, wheel...done.
[gibson@rickenbacker virtualenvs]$ source ydk-py-venv/bin/activate
(ydk-py-venv) [gibson@rickenbacker virtualenvs]$
(ydk-py-venv) [gibson@rickenbacker virtualenvs]$ which python
~/PythonProjects/virtualenvs/ydk-py-venv/bin/python
(ydk-py-venv) [gibson@rickenbacker virtualenvs]$ which pip
~/PythonProjects/virtualenvs/ydk-py-venv/bin/pip
(ydk-py-venv) [gibson@rickenbacker virtualenvs]$ pip list
pip (8.1.2)
setuptools (28.6.1)
wheel (0.30.0a0)
Then I installed the YDK core module as shown below...
(ydk-py-venv) [gibson@rickenbacker virtualenvs]$ cd ../ydk-py
(ydk-py-venv) [gibson@rickenbacker ydk-py]$ ls
CHANGES.md  cisco-ios-xr  Copyright  core  ietf  LICENSE  openconfig  README.rst
(ydk-py-venv) [gibson@rickenbacker ydk-py]$ cd core
(ydk-py-venv) [gibson@rickenbacker core]$
(ydk-py-venv) [gibson@rickenbacker core]$ python setup.py sdist
running sdist
running egg_info
creating ydk.egg-info
writing requirements to ydk.egg-info/requires.txt
writing ydk.egg-info/PKG-INFO
writing top-level names to ydk.egg-info/top_level.txt
writing dependency_links to ydk.egg-info/dependency_links.txt
writing manifest file 'ydk.egg-info/SOURCES.txt'
reading manifest file 'ydk.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: sdist: standard file not found: should have one of README, README.rst, README.txt
running check
creating ydk-0.5.1
creating ydk-0.5.1/ydk
creating ydk-0.5.1/ydk.egg-info
creating ydk-0.5.1/ydk/_core
creating ydk-0.5.1/ydk/mdt
creating ydk-0.5.1/ydk/models
creating ydk-0.5.1/ydk/providers
creating ydk-0.5.1/ydk/services
copying files to ydk-0.5.1...
copying MANIFEST.in -> ydk-0.5.1
copying README.md -> ydk-0.5.1
copying setup.py -> ydk-0.5.1
copying ydk/__init__.py -> ydk-0.5.1/ydk
copying ydk/errors.py -> ydk-0.5.1/ydk
copying ydk/types.py -> ydk-0.5.1/ydk
copying ydk.egg-info/PKG-INFO -> ydk-0.5.1/ydk.egg-info
copying ydk.egg-info/SOURCES.txt -> ydk-0.5.1/ydk.egg-info
copying ydk.egg-info/dependency_links.txt -> ydk-0.5.1/ydk.egg-info
copying ydk.egg-info/requires.txt -> ydk-0.5.1/ydk.egg-info
copying ydk.egg-info/top_level.txt -> ydk-0.5.1/ydk.egg-info
copying ydk/_core/__init__.py -> ydk-0.5.1/ydk/_core
copying ydk/_core/_dm_meta_info.py -> ydk-0.5.1/ydk/_core
copying ydk/mdt/__init__.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/event_tcp.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/proto_to_dict.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/proto_to_ydk.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/receiver.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/simple_tcp.py -> ydk-0.5.1/ydk/mdt
copying ydk/mdt/telemetry_kv_pb2.py -> ydk-0.5.1/ydk/mdt
copying ydk/models/__init__.py -> ydk-0.5.1/ydk/models
copying ydk/providers/__init__.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_decoder.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_encoder.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_importer.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_provider_plugin.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_session_config.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_validator.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_value_encoder.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/_ydk_types.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/codec_provider.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/native_netconf_provider.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/netconf_provider.py -> ydk-0.5.1/ydk/providers
copying ydk/providers/provider.py -> ydk-0.5.1/ydk/providers
copying ydk/services/__init__.py -> ydk-0.5.1/ydk/services
copying ydk/services/codec_service.py -> ydk-0.5.1/ydk/services
copying ydk/services/crud_service.py -> ydk-0.5.1/ydk/services
copying ydk/services/executor_service.py -> ydk-0.5.1/ydk/services
copying ydk/services/meta_service.py -> ydk-0.5.1/ydk/services
copying ydk/services/netconf_service.py -> ydk-0.5.1/ydk/services
copying ydk/services/service.py -> ydk-0.5.1/ydk/services
Writing ydk-0.5.1/setup.cfg
creating dist
Creating tar archive
removing 'ydk-0.5.1' (and everything under it)
(ydk-py-venv) [gibson@rickenbacker core]$ pip install dist/ydk-0.5.1.tar.gz
Processing ./dist/ydk-0.5.1.tar.gz
  Requirement already satisfied (use --upgrade to upgrade): ydk==0.5.1 from file:///home/gibson/PythonProjects/ydk-py/core/dist/ydk-0.5.1.tar.gz in /home/gibson/PythonProjects/ydk-py/core
Collecting ecdsa==0.13 (from ydk==0.5.1)
  Using cached ecdsa-0.13-py2.py3-none-any.whl
Collecting enum34==1.1.3 (from ydk==0.5.1)
  Using cached enum34-1.1.3-py2.py3-none-any.whl
Collecting lxml==3.4.4 (from ydk==0.5.1)
Collecting paramiko==1.15.2 (from ydk==0.5.1)
  Using cached paramiko-1.15.2-py2.py3-none-any.whl
Collecting pyang==1.6 (from ydk==0.5.1)
  Using cached pyang-1.6-py2.py3-none-any.whl
Collecting pycrypto==2.6.1 (from ydk==0.5.1)
Collecting Twisted>=16.0.0 (from ydk==0.5.1)
Collecting protobuf==3.0.0b2.post2 (from ydk==0.5.1)
  Using cached protobuf-3.0.0b2.post2-py2-none-any.whl
Collecting ncclient>=0.4.7 (from ydk==0.5.1)
Collecting zope.interface>=3.6.0 (from Twisted>=16.0.0->ydk==0.5.1)
Requirement already satisfied (use --upgrade to upgrade): setuptools in /home/gibson/PythonProjects/virtualenvs/ydk-py-venv/lib/python2.7/site-packages (from protobuf==3.0.0b2.post2->ydk==0.5.1)
Collecting six>=1.9 (from protobuf==3.0.0b2.post2->ydk==0.5.1)
  Using cached six-1.10.0-py2.py3-none-any.whl
Building wheels for collected packages: ydk
  Running setup.py bdist_wheel for ydk ... done
  Stored in directory: /home/gibson/.cache/pip/wheels/73/68/7b/ad30d2c8d6b51e430590eeca4b2ac13d502f705e34dfb29f87
Successfully built ydk
Installing collected packages: ecdsa, enum34, lxml, pycrypto, paramiko, pyang, zope.interface, Twisted, six, protobuf, ncclient
Successfully installed Twisted-16.4.1 ecdsa-0.13 enum34-1.1.3 lxml-3.4.4 ncclient-0.5.2 paramiko-1.15.2 protobuf-3.0.0b2.post2 pyang-1.6 pycrypto-2.6.1 six-1.10.0 zope.interface-4.3.2
When I list the installed packages with "pip list" I can see ydk(0.5.1) is there...
(ydk-py-venv) [gibson@rickenbacker core]$ pip list
ecdsa (0.13)
enum34 (1.1.3)
lxml (3.4.4)
ncclient (0.5.2)
paramiko (1.15.2)
pip (8.1.2)
protobuf (3.0.0b2.post2)
pyang (1.6)
pycrypto (2.6.1)
setuptools (28.6.1)
six (1.10.0)
Twisted (16.4.1)
wheel (0.30.0a0)
ydk (0.5.1)
zope.interface (4.3.2)
However, when I change directories I no longer see it...
(ydk-py-venv) [gibson@rickenbacker core]$ cd
(ydk-py-venv) [gibson@rickenbacker ~]$
(ydk-py-venv) [gibson@rickenbacker ~]$ pwd
/home/gibson
(ydk-py-venv) [gibson@rickenbacker ~]$ pip list
ecdsa (0.13)
enum34 (1.1.3)
lxml (3.4.4)
ncclient (0.5.2)
paramiko (1.15.2)
pip (8.1.2)
pyang (1.6)
pycrypto (2.6.1)
setuptools (28.6.1)
six (1.10.0)
Twisted (16.4.1)
wheel (0.30.0a0)
Also, I expected to see ydk in the "site-packages" directory of the virtual environment Python instance...
(ydk-py-venv) [gibson@rickenbacker ~]$ cd PythonProjects/virtualenvs/ydk-py-venv/lib/python2.7/site-packages/
(ydk-py-venv) [gibson@rickenbacker site-packages]$ ls -l
total 192
drwxrwxr-x. 10 gibson gibson  4096 Oct 20 12:10 Crypto
-rw-rw-r--.  1 gibson gibson   126 Oct 20 12:08 easy_install.py
-rw-rw-r--.  1 gibson gibson   315 Oct 20 12:08 easy_install.pyc
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 ecdsa
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 ecdsa-0.13.dist-info
drwxrwxr-x.  3 gibson gibson  4096 Oct 20 12:10 enum
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 enum34-1.1.3.dist-info
drwxrwxr-x.  3 gibson gibson  4096 Oct 20 12:10 google
drwxrwxr-x.  5 gibson gibson  4096 Oct 20 12:10 lxml
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 lxml-3.4.4.dist-info
drwxrwxr-x.  5 gibson gibson  4096 Oct 20 12:10 ncclient
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 ncclient-0.5.2.dist-info
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 paramiko
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 paramiko-1.15.2.dist-info
drwxrwxr-x. 10 gibson gibson  4096 Oct 20 12:08 pip
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:08 pip-8.1.2.dist-info
drwxrwxr-x.  4 gibson gibson  4096 Oct 20 12:08 pkg_resources
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 protobuf-3.0.0b2.post2.dist-info
-rw-rw-r--.  1 gibson gibson   305 Oct 20 12:10 protobuf-3.0.0b2.post2-py2.7-nspkg.pth
drwxrwxr-x.  4 gibson gibson  4096 Oct 20 12:10 pyang
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 pyang-1.6.dist-info
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 pycrypto-2.6.1.dist-info
drwxrwxr-x.  4 gibson gibson  4096 Oct 20 12:08 setuptools
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:08 setuptools-28.6.1.dist-info
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 six-1.10.0.dist-info
-rw-rw-r--.  1 gibson gibson 30098 Oct 20 12:10 six.py
-rw-rw-r--.  1 gibson gibson 29545 Oct 20 12:10 six.pyc
drwxrwxr-x. 26 gibson gibson  4096 Oct 20 12:10 twisted
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 Twisted-16.4.1.dist-info
drwxrwxr-x.  5 gibson gibson  4096 Oct 20 12:08 wheel
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:08 wheel-0.30.0a0.dist-info
drwxrwxr-x.  3 gibson gibson  4096 Oct 20 12:10 zope
drwxrwxr-x.  2 gibson gibson  4096 Oct 20 12:10 zope.interface-4.3.2.dist-info
-rw-rw-r--.  1 gibson gibson   349 Oct 20 12:10 zope.interface-4.3.2-py2.7-nspkg.pth
But it isn't there!  What am I missing here?
We figured out that 'pip list' was showing ydk if we were in the ydk-py/core directory. Not sure why. Could be because somehow the PYTHONPATH was getting modified, but 'echo $PYTHONPATH' was not showing anything? After installing the tar file with 'pip install dist/*.tar.gz', pip was correctly showing ydk no matter which directory we were in.
BTW I couldn't reproduce this behavior on my centos VM either.
5 Replies 5
abhirame
Hi Jonathon,
I'm not able to reproduce this. When I install ydk using 'pip install', ydk shows up in the 'pip list' and in the virtualenv python site-packages, no matter which directory I'm in. Can you try to delete and create the virtualenv and try to install ydk again?
Actually, I did those steps twice already! In the log I posted earlier I had completely deleted the venv and ydk installation directories and started over.
Could we do a WebEx?
Sure. This is my link Cisco - Internal Sites WebEx Enterprise Site
Can you import ydk in the Python interpreter? I experience a somewhat related issue where pip doesn't list ydk even though it is installed and operation.  I only see the issue in my system install. Not in virtual environments.
$ pip list | grep ydk
$ python
Python 2.7.12 (default, Jul  1 2016, 15:12:24)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import ydk
In my experience, pip isn't always very reliable and, every once in a while, it get into inconsistent states.
